Fault LED indicates fault
I recently set up a System Blue.
The Fault LED is turned on. What does that indicate?
The controller indicates a GPS signal and Network (GPS led blinks, Network LED is turned on)
I wasn't able to find a description about how the LEDs should be interpreted. Is there such a description?
Can you reach the web GUI?
The fault LED lights when the controller is in interference mode. Whether it lights under other conditions I do not know.
Stations: 1075, 1472
(2016-06-30, 10:19)Andrew.Instone-Cowie Wrote: The fault LED lights when the controller is in interference mode. Whether it lights under other conditions I do not know.
Thanks.
I rearranged some cables and positioning of the antennas. The station is up running now.
i have the same problem but it´s the alarm red is on all the time ??
Stations: 148, 1598, 1601
(2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
What abput the other LED's?
What about the Web-GUI, can you read the system status on the browser?
Are you in "normal" mode or "interference"-mode?
73 de Hartmut / DK5LH
Stations: 1582
the other LED's? they ar ok
What about the Web-GUI, can you read the system status on the browser, how do i do that?
no interference.
Stations: 614
no interference.
Aehmmm, you never did any configuration on the embedded web-server  of the system?
Maybe there is a misunderstanding...
- Check your router and find out what IP adress your System Blue got
- type in the IP adress in your browser
- you should see now the WEB-GUI and all information or configuration tabs
- see also here: http://de.blitzortung.org/cover_your_area.php?session=1  ; download the manual and read beginning of page 69
- maybe you did not disable AMP1 or AMP2 if there is no antenna connected to any of the input terminals?
Good luck!
Stations: 1582
no interference.
Good luck!
Thank i find it now its working fine now
no interference.
Good luck!
I also have an error.
And no interface available.
Hardfault error
Please report
LR=8038f73
PC=80347d4
Firmware 8
After reset unit works.
Stations: 907
(2016-09-19, 18:17)Arnaut.Stomphorst Wrote: I also have an error.
Hardfault error
Please report
LR=8038f73
PC=80347d4
Firmware 8
Thanks for the info. This specific error shouldn't happen any more now.
  Fault mode after big electrostatic discharges. ant01n3 1 579 2024-01-30, 22:55
Last Post: dupreezd
  fault led at first boot uvash 3 11,238 2021-11-18, 10:37
Last Post: aloha20
  How to get alerts of fault or missing GPS jchonig 2 8,012 2020-12-30, 18:23
