Optimum Gain Setting for System Red
I operate a system red detector to provide coverage for northern Arizona and Southwestern USA.  I can always operate at a gain of 8 X 4 X 40, and when there is no local electrical interference I can increase the gain to 8 X 10 X 40.  I use the ferrite rod antennas supplied with the system red.
The higher gain setting allows detection of very distant lightning, but higher gain does not appear to be as sensitive to nearby lightning.
Does a high gain setting result in nearby lightning overloading the system red?  Have others experienced this problem?  What gain settings seem to work best for you?
Thank you,
Joe
Flagstaff, Arizona
Stations: 1225
(2015-05-14, 14:27)Nova01 Wrote: I operate a system red detector to provide coverage for northern Arizona and Southwestern USA.  I can always operate at a gain of 8 X 4 X 40, and when there is no local electrical interference I can increase the gain to 8 X 10 X 40.  I use the ferrite rod antennas supplied with the system red.
Thank you,
Joe
Flagstaff, Arizona
Hi Joe,
I think the best answer is to go for the (relatively) nearby strikes. When the distance increases the radiosignal by the lightning changes a bit, and the accuracy decreases, due to relection of the signal. And very nearby strikes (<100 km) is also not accurate, due to the pre-discharges, where lightning "finds a path". This pre-discharge is ahead of the real lightningstrike. So the 100 to 1000 range should be ideal for the system as a whole!
Gerhard
Stations: 711, 1351
Hi !
The best setting is, if your location ratio and stroke ratio is better than the main. Try to find a setting, both values togehter are max, but do not tune one value to a maximum !
Thomas
Stations: 1006, 1305
There is no gain setting to cover both, far and close strikes:
You can change the gain setting for close strikes.
Though it is very difficult to find a good setting because of the enormous amplitude differences among the strikes, you will still miss a lot of strikes and record "noise".
Stations: 233
  Low gain on this system (Waregem) Noodweer Benelux 9 46,360 2015-07-18, 03:09
Last Post: JamesPatterson
