Building a red system
Jack,
Nice work on the ferrites! Smile
Your signals don't appear to have much noise in them so your location must be pretty clean. I watched your signals for a few minutes. At first i saw both H-field and E-field but now, for some reason, only H-field and of that, mostly only Channel 1 (Red trace). There is an occasional Green trace but not very often. Are you sure everything is connected solidly? Check the antenna connections and ethernet & coax cables for tight connections.
Are you running in manual mode or Automatic?
Also, are you a ham? You mention the Elecraft K-1...
Stations: 808
Building a red system - by Jack Zielke - 2014-10-09, 02:04
RE: Building a red system - by W3DRM - 2014-10-09, 04:19
RE: Building a red system - by Jack Zielke - 2014-10-09, 04:51
RE: Building a red system - by W3DRM - 2014-10-10, 16:02
RE: Building a red system - by Jack Zielke - 2014-10-26, 07:22
RE: Building a red system - by cutty - 2014-10-26, 10:15
RE: Building a red system - by Jack Zielke - 2014-10-26, 22:54
  Building a Blue - Optional SMA connectors? Mike6158 4 22,762 2017-04-09, 22:20
Last Post: RichoAnd
