Nearby Power Lines
At one point, I had the opportunity to do some work on broadband over power line system measurements, and power line noise was a pretty big factor even up into the HF/VHF range. For E-field, at lower voltages (the MV lines you see in residential areas), bad insulators can produce all sorts of nonlinear effects (there's a certain type, widely used, that's particularly notorious for this and responsible for a lot of the ambient power line noise). But even at higher voltages, insulators can go bad. You'll never know until you try.
Stations: 1013
Nearby Power Lines - by Steve_Bell - 2014-07-14, 16:00
RE: Nearby Power Lines - by DelandeC - 2014-07-14, 16:56
RE: Nearby Power Lines - by Knickohr - 2014-07-14, 17:15
RE: Nearby Power Lines - by cutty - 2014-07-14, 17:24
RE: Nearby Power Lines - by Steve_Bell - 2014-07-14, 21:00
RE: Nearby Power Lines - by carseman - 2014-07-14, 21:43
RE: Nearby Power Lines - by MeteoCercal - 2014-07-14, 23:36
RE: Nearby Power Lines - by cutty - 2014-07-14, 23:54
RE: Nearby Power Lines - by Mark.Smith - 2014-08-05, 14:20
RE: Nearby Power Lines - by MeteoCercal - 2014-07-15, 00:58
RE: Nearby Power Lines - by cutty - 2014-07-15, 01:05
RE: Nearby Power Lines - by MeteoCercal - 2014-07-15, 02:53
RE: Nearby Power Lines - by Steve_Bell - 2014-07-15, 09:10
RE: Nearby Power Lines - by RichoAnd - 2014-07-15, 16:48
RE: Nearby Power Lines - by Steve_Bell - 2014-07-16, 11:03
RE: Nearby Power Lines - by Tobi - 2014-07-15, 20:47
RE: Nearby Power Lines - by Jonathan.Williams - 2014-07-16, 12:32
RE: Nearby Power Lines - by Donald.Froula - 2014-07-16, 15:07
RE: Nearby Power Lines - by MilanBar - 2014-07-16, 20:18
RE: Nearby Power Lines - by cg617 - 2014-07-26, 15:27
RE: Nearby Power Lines - by Jonathan.Williams - 2014-08-03, 14:52
RE: Nearby Power Lines - by billhoblit - 2014-08-20, 16:15
RE: Nearby Power Lines - by cutty - 2014-08-20, 17:06
RE: Nearby Power Lines - by billhoblit - 2014-08-20, 17:24
RE: Nearby Power Lines - by StElmo - 2014-08-21, 00:37
RE: Nearby Power Lines - by cutty - 2014-08-20, 18:16
RE: Nearby Power Lines - by W3DRM - 2014-08-20, 19:43
  E-Field Antenna and 60 Hz power lines waysta 4 23,806 2017-06-09, 23:11
Last Post: radiofarol
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 15,480 2015-09-18, 20:53
Last Post: br1ght
