No more data transmitted Europe 2 and 3
(2023-08-23, 08:13)Benjamin Wrote: This can happen for a number of reasons, here are some possible solutions and troubleshooting steps:
Check network connection: Make sure your probe is properly connected to the network. Check that the network cable or Wi-Fi connection is stable and that the network settings are correct.
Confirm Area Coverage: Verify Europe 2, Europe 3 and Africa 1 area coverage and make sure your detector is in good signal coverage. You can try to reinstall or adjust the position of the detector to get a better signal.
Check device settings: Make sure your detector is set up correctly. Check that the probe is properly configured to transmit data in the Europe 2, Europe 3 and Africa 1 regions and is not set to block data transmission.
Update firmware and software: Check for available firmware or software updates. Sometimes an update can fix some issues related to data transfer. Please follow the manufacturer's guidelines for updates.
Contact technical support: If none of the above steps solve the problem, it is recommended that you contact the detector's manufacturer or technical support team. They can provide more specific guidance and assist you with this problem.
Not having the same problem with your blue 2783 detector may be due to a different model or configuration. Each device may have its own independent features and settings, so the causes and solutions for problems may vary.
Hope these tips help you and good luck with your problem solving!
Absolutely irrelevant for the most part,
Region assignments are more or less 'arbitrary'...
  Map active Stations Blitzortung Europe patoffgrid 2 23,554 2024-06-22, 17:02
Last Post: patoffgrid
  definition Europe/ North America RiePa 5 50,398 2024-06-16, 15:32
Last Post: gerbold
  No lightning data (Europe) Noodweer Benelux 2 26,993 2017-08-12, 10:34
  Lightningmaps.org Radar Europe Gerhard.Wittevee 2 32,611 2015-07-09, 20:04
Last Post: Gerhard.Wittevee
  Intermittend Idle problems Europe WSOverijse 4 43,596 2015-03-14, 17:01
