blue ferrite / loop antenna connection?
(2020-10-20, 08:22)MTO-Mareuil Wrote: Hi,
can you tell me what is the best connection on the blue preamp between loop antenna or ferrite antenna? it has 3 inputs per antenna E1-E2-GND
Ferrite = E1-E2 and GND what is the correct connection?
Loop E1- E2 -?
Loop E1- GND -?
Loop E2- GND -?
(after soldering the bridge under the pcb)
Thank you for bringing me some details.
kind regards
Patrick Smile
For ferrites, three jumpers should be left open.  Those are for air core loops.
The block "GND" is for a shield ground. open otherwise.
Loop ends connect to the + and - only.  Polarity does NOT matter.
For the E pre-amp... the probe goes to the 'inboard' block, the'outer' will always be open.  There should be NO other
connections to anywhere, except the coax itself, to the E preamp.  Zero. Nil.  doing elsewise really messes up the 'mirror' capacitance of the probe, between the probe and earth. That 'capacitance' is what does the work. Don't do anything extra.
See: https://forum.blitzortung.org/showthread.php?tid=2749
RE: blue ferrite / loop antenna connection? - by cutty - 2020-10-20, 11:43
  air-core loop connection to H-field preamplifier 23.1 GeezerD 2 18,966 2025-10-16, 07:54
Last Post: merc82
  Blue e-field antenna question llowrey 2 21,683 2021-07-06, 14:34
Last Post: llowrey
  GPS antenna SYSTEM BLUE ! IK1TTD 9 74,774 2020-06-03, 12:16
Last Post: GJ7DNI
  Blue System: PreAmp & Antenna Questions BassJohn 5 45,246 2018-02-28, 08:41
Last Post: BassJohn
  System Blue Voltage regulator and antenna SteveQlQ 3 33,065 2017-08-12, 14:32
Last Post: RichoAnd
