Blue System: PreAmp & Antenna Questions
(2018-02-27, 18:38)BassJohn Wrote: 1) On the pre-amp board are the connectors A-1,A-2 and B-1,B-2 relate to the vertical antennas?
2) On the pre-amp board is the connector C-1,C-2 for the optional horizontal antenna?
3) I intend to use my loop antenna I had on my Green system, Which I was under the impression it did not matter which way it pointed, is this still so?
4) On the Green system the loop antenna windings were wound in a certain direction, and had to be wired up to the Green pre-amp the correct way, is this still so for the Blue system, if so which end of the loop goes to which connector (1, 2) ?
Hello John,
Dave just beat me to it, but my answer was going to include a link to this documentation that explains a lot of what you asked.
3) It does not matter how you orient your antennas
4) It doesn't matter .
RE: Blue System: PreAmp & Antenna Questions - by mwaters - 2018-02-27, 22:35
  Blue Preamp and Red Controller? Reiner.vom.Bruch 1 483 2024-04-22, 08:22
Last Post: Reiner.vom.Bruch
  Blue e-field antenna question llowrey 2 7,616 2021-07-06, 14:34
Last Post: llowrey
  blue ferrite / loop antenna connection? MTO-Mareuil 1 6,927 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 47,689 2020-06-03, 12:16
Last Post: GJ7DNI
  System Blue Voltage regulator and antenna SteveQlQ 3 18,966 2017-08-12, 14:32
Last Post: RichoAnd
