(2017-08-16, 01:39)kevinmcc Wrote: Yes, just map the port to System Blue IP address.
Not sure what the server software is.
Only setting on System Blue is a check box to enable or disable NTP server.
It uses the GPS time together with the local 1 PPS timing pulse.
enable the NTP server,
for example, in Windows, go to cliock settings,
set by internet,, and paste the controller LAN url into
the server select box, as in attached....
(remember the default lan is...235 not 217)
Now, the clock did set, when I tried connecting from WAN
but indicated that it 'didn't' because it timed out....
This is another 'add on' that can slow the controller down, by the way.
