Newly assembled System Blue problems
(2017-07-16, 20:02)kevinmcc Wrote: Looking at the soldier joints, some appear to have a lot of solder that flowed through the via, others do not.
I would double check that the solder joints are making good connections and none are shorting.
Are you still using a 1A power supply?
You may want to try a bigger supply.
Had really good luck with this one.
I re-checked every solder joint with a multimeter and I still haven't found anything suspicious.
Still using the 1A supply; I don't think I have a USB power supply with more than 1A output, I'll have to look.
RE: Newly assembled System Blue problems - by bogdan - 2017-07-16, 21:29
Smile System Blue 19.5 Board Assembled For Sale carolinastormwatch57 1 8,526 2021-02-12, 10:30
Last Post: Alvarezz
  New System - two (minor) problems Kingfisher 1 11,699 2018-06-23, 17:23
Last Post: Kingfisher
  Assembled my E-field kit. Remy Brandt 17 115,799 2015-02-20, 12:24
