System Blue - Rocker Switch Question
Hi Jeff,
I guess there is no connector which can be soldered with wires to the rocker switch.
3 suggestions:
- Use a jumper to connect pin 5 and 6 of S1 while you get an appropriate connector.
- Solder short wires at the rocker switch and at the bottom side of the PCB to pin 5 and 6 of S1.
- Solder short wires at the rocker switch and directly at the connection plug to pin 5 and 6.
CU Robo Smile
Stations: 92, 1563
RE: System Blue - Rocker Switch Question - by robo - 2016-09-09, 01:28
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 50,868 2025-04-19, 23:25
Question Question about the antena in system Blue BlackRockShooter 7 58,835 2020-08-25, 11:23
  Using the on/off switch with the new Blue enclosure Dale.Reid 7 57,999 2016-11-15, 02:36
Last Post: Dale.Reid
  System Blue Network Interface Question chevyman142000 13 95,821 2016-09-19, 20:21
Last Post: chevyman142000
  Registering new system question.. Aythya 8 67,990 2016-05-12, 07:21
Last Post: Knolau
