Odd socket in RED kit
I'm building the RED controller at the moment and I have come to putting the socket on the for the LCD. The kit includes two 10 position socket strips, but the board has holes for two 9 position socket strips.
I can easily clip off one of the pins to get it onto the board, but I thought that I would check first before doing that -- in case I am missing something obvious.
Also does the voltage regulator have to be screwed to the board?
Philip
Yep, clip 'em off.
Might want to double check the assembly instructions.... there are several fine points of assembly that can cause grief later.... including the one you ran into...
W3DRM has some excellent 'gotchas' and other assembly instructions at
http://www.wxforum.net/index.php?topic=20037.0
And I did put a dab of heat sink compound, and bolt my regulator to my board, ... some folks have, some haven't... not a lot of current or heat, but old habits die hard in my case.
Happy Ortungs!
(2014-09-23, 12:33)Cutty Wrote: W3DRM has some excellent 'gotchas' and other assembly instructions at
I wish that I had found these instructions before I built the board. I may have to redo some stuff (and visit Digikey to get replacement components). The only instructions that I could find were in http://www.blitzortung.org/Documents/TOA...1411318751 and I just installed the components in the "obvious" way in the order listed in the document. It would have been nice for the piece of paper that came with the kit to point you at assembly instructions.
Argh!
Philip
Smile
Well, it does help to browse through all the various forum listings... lots of hard won experience here and at the other forums. Most anything you run into has been discovered and answered if you search... and we're still discovering tricks and tips.
As a result of a member not seeing the post that shows information for new installations/builds, I have made the post I created on the subject of Blizortung System Red & E-field Step-by-Step Build Documents under the 'Internal/Station Hardware and Firmware' board a 'sticky'. This should make it more visible to everyone in the future.
Sorry Philip, we live and learn as we go...
Stations: 808
(2014-09-23, 20:05)W3DRM Wrote: As a result of a member not seeing the post that shows information for new installations/builds, I have made the post I created on the subject of Blizortung System Red & E-field Step-by-Step Build Documents under the 'Internal/Station Hardware and Firmware' board a 'sticky'. This should make it more visible to everyone in the future.
Hey -- I'm making progress! I have the STM32 board mounted, powered up and flashing away nicely (and the GPS came into lock without needing the external antenna).
By the way, I can't access that link to the board above (or even reply to your DM). I suspect that I need to get my id upgraded. I've sent email and hope to make progress tomorrow.
Now on to build the E-Field amplifier board.....
Philip
Philip
That is correct. You will not have access to the internal forum until you have requested it as explained in the Blitzortung documentation.
Stations: 808
  Buying a station / kit. Anyone? pinnladan 8 20,453 2025-06-19, 02:02
Last Post: Vier1998
  Assembled my E-field kit. Remy Brandt 17 139,566 2015-02-20, 12:24
  Unassembled kit pics Donald.Froula 7 61,181 2014-06-17, 13:29
Last Post: preape
  Kit Construction N1LF 6 53,636 2014-04-23, 21:34
Last Post: Ross.Wheeler
Users browsing this thread: 8 Guest(s)
