Receiver situation
Where do I configure the city and country settings on my receiver?
Thank you very much!
https://www.blitzortung.org/login.php
You can update your personal info here.  NOTE: "Anonyn" means exactly that. IF you 'Y' you will NOT be visible to public, maps, etc.  Suggest leave it 'N'.
Scroll down
Your station info is below that 'profile' info, You should enter your antenna configurations while there.
You also enter the city, country, etc for that specific station,...again, "Anonyn" 'Y' means that station WON'T be visible. Suggest leave it 'N'. then scroll down past the 'last signal' images, and click "save"
Now that your GPS problem is solved, there is another little detail to update
antenna description in the settings, this will help the servers to decode your signal
this is mine
and yours
the settings part
You can also update the firmware to 11B3 (even if it is labeled beta it is stable and it has some improvements for signal and some extra stuff to play with)
https://docs.lightningmaps.org/station-o.../firmware/
(2025-12-27, 10:05)Eric.Wouters Wrote: Now that your GPS problem is solved, there is another little detail to update
this is mine
and yours
the settings part
Is it possible to load this firmware version for the Blue Mini?
this is mine
and yours
the settings part
yes... just make sure you get the 'blue.bin' file.  See the PM I sent yesterday...
this is mine
and yours
the settings part
ok, thank you
  How does one become a receiver station builder? Moonbouncer 1 22,936 2020-04-30, 14:22
Last Post: vinesweather
  Buying a receiver Yoggie 2 39,284 2017-05-24, 21:49
Last Post: allsorts
  Looking for a receiver va3mw 4 42,314 2014-07-16, 15:46
Last Post: va3mw
