Station not showing up
Hi Folks,
My station (3083) a blue mini went fully operational yesterday but it doesn't appear to be showing up on https://www.lightningmaps.org although it's visible on https://map.blitzortung.org/
Is there something I'm doing wrong?
Paul.
It's there, right in the middle of the map: https://map.blitzortung.org/#8.51/50.9212/0.0265
Stations: 3050
(2024-09-02, 09:49)Kets_One Wrote: It's there, right in the middle of the map: https://map.blitzortung.org/#8.51/50.9212/0.0265
But it's not showing up on Lightningmaps.org. Is there a registration process or something?
Another question on the Blitzortung vector map: Why do some stations show a dot on the end of an active detector link? They disappear after about 4-5 seconds. What do they mean and why does my station not show them?
Stations: 3083
Just noticed that your station 3050 isn't showing up either. Maybe its a Blue Mini thing?
Stations: 3083
Hi Paul...
Welcome Aboard... I've upgraded your forum status to 'Participant', you now have 'internal' access, etc...
RE:  Lightningmaps.org:
See this forum post, for example, there are other posts similar:
https://forum.blitzortung.org/showthread.php?tid=3870&pid=25976#pid25976
RE: Yellow dots on Blitzortung vector...
I believe those indicate the station was a 'detector' for that specific stroke.
But don't know why they might not show otherwise. Blue Mini is 'new', and Egon may have a 'glitch' in the display... Angel
If your controller hasn't already suggested you upgrade your firmware to 10.1, you can do it manually...
https://forum.blitzortung.org/showthread.php?tid=3789
Make sure you download FW for BLUE --- NOT RED, follow the procedure on your controller's "Tools" page... easy.
Enjoy!
(2024-09-02, 10:46)cutty Wrote: Hi Paul...
Enjoy!
Thank you mike.
Stations: 3083
  Station Moved Country and Showing Wrong on LightningMaps Dave.Auld 5 5,892 2026-02-14, 21:27
Last Post: Dave.Auld
  Station List not showing any United Kingdom stations dgoadby 2 34,737 2019-04-15, 16:35
Last Post: dgoadby
