Threads: 0
Hello, could I get upgraded to participant status?
User ID: 1978
Station ID: 2545
User ID: uovgaz
Region: North America 1/2
Thanks!
Threads: 0
Station was recognized yesterday, missing from station list today
User name: SA2CLC
UserID : 2353
Station ID 2969
Location, Sweden
//Tommy
Threads: 64
(2023-05-30, 19:16)SA2CLC Wrote: Station was recognized yesterday, missing from station list today
User name: SA2CLC
UserID : 2353
Station ID 2969
Location, Sweden
//Tommy Your station is listed with no issues on Blitzortung.0rg Servers Europe 1, 2, and 3.
2023-06-15, 16:09
(This post was last modified: 2023-06-15, 16:37 by maciejhka.)
Today I launched my own builded station. Can I get upgrade to participant rank on forum?
Username: maciejhka
user number: 2363
station number: 2992
Region: Europe, Poland
Thank you
Threads: 0
Hello,I can't find my station in station list.
User Name: BruceBob
Station Number: 2994
User ID: 2364
Region: Asia
BruceBob
Threads: 2
IanL01
Station 1559
LightingMaps.org
Duplicate stations seen
Going from the link in the device
https://www.lightningmaps.org/blitzortun...o_sid=1559
Shows station active Yes
Pages shows a link other station for this user 1559
select that link
goto
https://www.lightningmaps.org/blitzortun...ion_id=117
Shows Station active yes/no reception. Last detected stroke 2021-03-02
Comment field updates if I change in Blizortung.org
Threads: 64
(2023-07-04, 23:05)IanL01 Wrote: IanL01
Station 1559
LightingMaps.org
select that link
goto
Usually this happens when a station as been off-line at the last Blitzortung update, the last time Tobi synced LMO with Blitzortung (which are being constantly revised) you would be out of sync in the LMO listings. Note that Blitzortung is revising 'reporting region' assignments and other parameters. You want to use the tools available on the Blitzortung site,
Your station 1559 is currently assigned to report strikes in 4 region servers, which Lightningmaps does not read, as yet.
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Threads: 64
2023-07-05, 13:31
(This post was last modified: 2023-07-05, 13:32 by cutty.)
(2023-06-29, 01:11)brucebob Wrote: Hello,I can't find my station in station list.
User Name: BruceBob
User ID: 2364
Region: Asia
BruceBob
BruceBob...
1 . IF your station hasn't actually sent signals, it will NOT activate on Blitzortung database.
2. IF your station isn't configured properly on the Blitzortung Operator's page,
SPECIFICALLY if "anonym" is 'Y', than your station won't display. Make 'anonymous' = N for 'No'.
Threads: 2
(2023-07-05, 13:25)cutty Wrote: (2023-07-04, 23:05)IanL01 Wrote: IanL01
Station 1559
LightingMaps.org
select that link
goto
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Thanks for the update. So its just a matter of waiting for the assignment to be updated/revised and a sync to take place, is that correct.
Threads: 64
(2023-07-09, 00:36)IanL01 Wrote: (2023-07-05, 13:25)cutty Wrote: (2023-07-04, 23:05)IanL01 Wrote: IanL01
Station 1559
LightingMaps.org
select that link
goto
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Thanks for the update. So its just a matter of waiting for the assignment to be updated/revised and a sync to take place, is that correct. This thread is for the stations list on the parent Blitzortuung.org -- the actual computing platform. Your are listed correctly there. I cannot speak for when Tobi will restructure and sync the adjunct Lightningmaps.org. See this reply re map data:
https://forum.blitzortung.org/showthread...0#pid25170
Threads: 64
2023-07-09, 05:55
(This post was last modified: 2023-07-09, 05:56 by cutty.)
(2023-07-09, 00:36)IanL01 Wrote: (2023-07-05, 13:25)cutty Wrote: Usually this happens when a station as been off-line at the last Blitzortung update, the last time Tobi synced LMO with Blitzortung (which are being constantly revised) you would be out of sync in the LMO listings. Note that Blitzortung is revising 'reporting region' assignments and other parameters. You want to use the tools available on the Blitzortung site,
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Thanks for the update. So its just a matter of waiting for the assignment to be updated/revised and a sync to take place, is that correct. This thread is for listings on the Main Blitzortung.org servers, NOT lightningmaps.org, so I cannot speak to when Tobii will re-address, for the umpteenth time, the databases and processing on the adjunct lightningmaps.org. He wisely isn't updating all/many of the databases and processes etc, with all the revisions going on with the Blitzortung regional computing servers... un-necessary work until Egon finalizes all the modifications... . For example, the network now computes to a very large number of 'regional' signal/stroke assignments, LMO basically assigning to only 3, awaiting stabilization of new definitions, etc. I suggest you use and review the official data available on the 'official' site.
Threads: 2
(2023-07-09, 05:55)cutty Wrote: (2023-07-09, 00:36)IanL01 Understood. Thanks Wrote: (2023-07-05, 13:25)cutty Wrote: Usually this happens when a station as been off-line at the last Blitzortung update, the last time Tobi synced LMO with Blitzortung (which are being constantly revised) you would be out of sync in the LMO listings. Note that Blitzortung is revising 'reporting region' assignments and other parameters. You want to use the tools available on the Blitzortung site,
1559 Japan 1
1559 Oceania 1
1559 Asia 1
1559 Japan 2
Threads: 3
User name: tickertapes
UserID :2397
Station ID 3083
Location, Scaynes Hill, United Kingdom
Station not showing up in Lightningmaps.org Europe. Shows up okay in Oceana & America
https://www.lightningmaps.org/blitzortun...ow=station
User name hokie_emt
Station number 3087
Region Asia
Station details at top of statistics page not updating. stuck on 18 August. Lat/lon incorrect. Firmware incorrect, etc.
https://map.blitzortung.org/statistic_0....nsparent=1
Threads: 4
user name = geezerd, dellel
station number = 3174
region = Europe 1, Europe 2, Europe 3
user id = 2439
Either delete geezerd so i can participate as dellel, or upgrade geezerd to participant and abandon user name dellel.
Either way, retain my email address and station number.
When I log into the forum as dellel, I get an internal error 500 from SQL in the server.
I couldn't find the link to upgrade my existing geezerd to participant, so I registered dellel with the same email address. Whoops: bad.
thanks.
Threads: 11
(2025-06-24, 15:04)GeezerD Wrote: user name = geezerd, dellel
user id = 2439
thanks.
I only have a part of the access, I upped your profile on the forum for now. You'll see the inner part. Happy reading.
Regarding your account for the station, that I can't solve since I have no access to that part. I'll ping big boss Egon
Threads: 4
(2025-06-25, 07:15)Eric.Wouters Wrote: (2025-06-24, 15:04)GeezerD Wrote: user name = geezerd, dellel
Thanks for the quick work, Eric.
Threads: 5
Station # 1076
Canada (Komoka)
Recent purchase from former user (Komoka 955).
Sent email to Egon to initiate removal of unit from account so I can register.
I think he did what was needed as the unit seems to be gone from database and link is in the control interface to register.
(It is running and showing strikes on the map)
When I click link, it takes me to "lmaps.org/user/register?station=1076_xxxxxxxxxxxxxxxxxxxx" and gives 500 Internal Server Error.
TIA
D
Threads: 5
(2025-06-29, 17:21)davidmc36 Wrote: Station # 1076
Canada (Komoka)
TIA
D
To anyone who may have effected a fix to my issue, thanks a million!
All is set up now.
D
Threads: 11
Hi David,
I have upped your account to participant since I see your station on official map. I can't help regarding other parts outside the forum since I have no access to that part.
Egon is your best bet.
