2017-11-28, 13:27
Hello community,
I'm new here and got my kit today and soldered right away.
It lacks only the 2 filter IC's because I am not clear in which filter I should solder them.
There are 4 on the circuit board.
Does not it matter?
First everything built into the case and then connected a 5V 2A power supply.
The red power LED lights up and it beeps twice -
then the mode LED flickers very weak and after some time it beeps again.
The LEDs on the network socket light or flicker with the traffic on the network.
Unfortunately, I get from DHCP (SBS Server 2011) obviously no IP address.
Even a test for a new router with DHCP was unsuccessful.
Have again taken the board out of the housing and tested all solder joints - looks good.
Inside, the red LED on the GPS receiver is flashing. There is a new GPS antenna connected.
The 2 crystals are on the correct position.
Does anyone have a tip for me ....
Greetings from Carinthia,
Does not it matter?
