Threads: 14
2015-06-27, 14:07
(This post was last modified: 2015-06-27, 14:10 by Knickohr.)
This is the same situation as with my ferrite !
I cannot trigger on h-field because of heavy disturbers. But maybe you can trigger on e-field channel C.
Try :
Go to the settings tab
- manual mode
- set alternate channel mapping off, yes really off !
- set auto adapt to noise on
- set auto ampl. filter on
Go to the signal tab
click on amplifier 2
- set threshold for channel A and B to 0
- set threshold for channel C to 35mV
- set gains for channels to about 16x10
OK, watch channel C for gains. Gains will now change. If the system have found a good gain, then go again to the settings of amplifier 2. Now set gains for Channel A and B manually. But be carefull, the first number must be the same as the automatic found for channel C. Now play with the gains (middle number) of channel A and B for good and strong singals, but do not overtune it, do not override or clip singals.
P:S: your friend means that : https://en.wikipedia.org/wiki/Isolation_transformer
(but I'm nor sure if this really works !)
Thomas
Stations: 1006, 1305
Threads: 63
2015-06-27, 14:28
(This post was last modified: 2015-06-27, 14:29 by cutty.)
(2015-06-27, 14:07)Knickohr Wrote: P:S: your friend means that : https://en.wikipedia.org/wiki/Isolation_transformer
Thomas
Now, that is sort of cute, and a good one on me... English is my language, and I have to do a lot of Google translate...
Gert spelled it, for me, as " govanis trova" in his email... so playing around awhile I came up with something like
"Galvanic Detector".. possibly meaning an EMI meter..
These language things can be confusing....
I Think the display runs backwards, at times, in Gert's movie, because of the different frame rates in Gert's SWF, and the frame rate of the Signals display... and means little other than the frequencies of the noise may also vary in addition... resulting in that effect.
Threads: 14
Threads: 25
hi Thomas and Mike
I made a abc error its Galvanic trafo oeps
but it works the same like this page http://www.epanorama.net/circuits/antenna_isolator.html
Only I don't need it between the antenna cable but between the 230v power line !
it will stop the noise from the input to the output to my 230v cable
next week I will go again to that friend and hope he can deliver it ?
I have google it but can not find it here .. only the pro stuff and that is to much money !
hope to know next week more
thanks for al the help
greetings Gert
Threads: 14
2015-06-27, 17:19
(This post was last modified: 2015-06-27, 17:19 by Knickohr.)
Where do you want to install this isolator-transformer ?
What powersupply do you use for your station ?
Thomas
Threads: 25
2015-06-27, 17:33
(This post was last modified: 2015-06-27, 17:35 by Rothuize.)
(2015-06-27, 17:19)Knickohr Wrote: Where do you want to install this isolator-transformer ?
Thomas
between the power socket and the socket( 1 in and 6 sockets out ) to the computer and Blitzortung board
powersupply board = the power socket from Blitzortung 230 to 5 V
Threads: 23
Isolation transformers can (depending on type) transduce several 100kHz, so this probably won't work very well and is expensive.
I'd recommend putting a choke between the PSU and the controller. Make as much as possible windings on a Epcos T37 ring core, or N30. This will help, if the noise is coming from the power line.
I made some measurements on that:
But as i said earlier, a clean grounding is most important for e-field. Vertical ground rods don't work well, because the current is seperating at earth surface due skin effect, leaving a big ground resistance.
Ideally large expanses of vertical wires just below earth surface are used. the more and the longer, the better.
But a direct wire to the water supply pipe will be enough for our purpose in most cases, as long the pipe is of metal and not PVC.
Threads: 14
Yes, what type, model, brand of the 5V power supply do you use ?
Thomas
Threads: 25
(2015-06-27, 17:42)Knickohr Wrote: Yes, what type, model, brand of the 5V power supply do you use ?
Thomas
GooBay model 44005 input 100-240VAC 50/60Hz Output 5V DC 1A
and I know what you are thinking
But this is not the noise maker on this moment I run the power from the PC ( USB) to the Board
but all is still the same
Threads: 25
2015-06-27, 18:06
(This post was last modified: 2015-06-27, 18:11 by Rothuize.)
(2015-06-27, 17:41)Steph Wrote: Isolation transformers can (depending on type) transduce several 100kHz, so this probably won't work very well and is expensive.
that's a nice setup only this is not possible here
I don't live free
and thanks for the info .... choke will keep it in mind
my ground is coming from my second grounding punt
not in this house but this one is outside no powerline on this one
ground from water pipe not possible its PVC
Threads: 14
2015-06-27, 18:10
(This post was last modified: 2015-06-27, 18:11 by Knickohr.)
Ahhh,
these f... electronic switching power supply.
Why do you not use an "old fashioned" power supply with an big and heavy transformer in it ? If you use such an old linear regulator you have an build-in isolator-trafo in it. And the linear voltage regulator gives an excellent noise-free 5V supply. And if this doesn't work good enough, add an big choke, as Steph post before.
http://de.farnell.com/webapp/wcs/stores/...er=2431582
Powering the BO-station from PC is the worst thing you can do. A PC is a "mudslinger" as it's best !
Thomas
Threads: 25
(2015-06-27, 18:10)Knickohr Wrote: Ahhh,
Thomas
;-) normal I don't just the PC als power supply only now for 2 min
and ok that ## thing is no good why I have this to my Board ?
and maybe I have a old one some ware but must look
so that one from the iphone will also not work ;-)
many info on 1 day
thanks for al the hard thinking
Gert
Threads: 25
hi just a little update
the power supply from the board make indeed lot of noise ( can hear it on a am radio very loud )
but this is not the cause
now I have also try a netfilter its a schaffner fs23638-10-07 but also with this many noise
so this will also not working
also I have to switch off all my power into the house and ask for some power to my neighbours
but also many noise
I have also call to the agentschaptelecom.nl but there say we can not help you ??
also I have sent a letter to the owner from that powerhouse (stedin) and wait for answer
more I can not do
greetings Gert
